damn cam belt
Hi all,
After much deliberation, (thinking th cam belt had been changed in japan before we brought her over)
Well its gone (where you may ask). bugger....
Steve I will need a new one if you have any in stock... also anything else i might need. Will have to wait to see how much dameage had been done to the engine .
Also any garages in the midlands, I think there is one in shrewsbury, but any other would help.
Cheers in advance all
Rgds
Pete, Sue and poorly beat!!!
Had mine done at stuart grahams in Nantwich, cheshire. They are quite good at them now! theyve done 3 of mine!!
01270 780300 i think
I have a cam belt you can have if you get stuck was only on for 50 odd miles you are welcome to it,no tension spring though i think.
john
Cambelt supply not a prob.
Cambelt @ £32.97
Gasket set @ £125.42
Inlet valve @ £23.35 each
Exhaust valve @ £37.17 each
thanx
Thankyou all,
Will prob be in touch steve, just got to strip it down and see whats needed.
pete & Sue
arrrggghh
hi all,
after the engine being stripped down, guess what every damn valve is bent............
its going to be pricey, soo thinks to myself do any of you guys just happen to have a spare engine in your back pocket????
also Oz how much would an engine in japan cost, and what sort of timescale would we look at, much appreciated.
Pete & Sue
Well if you could get a head with all the valves that would solve the problem too. Honda Today has the same head as the Beat.
Cost wise I would think its best to just replace the valves, as Buying and Shipping an engine from Japan won't be that cheap, and you wont exactly know what your getting unless you strip it before you fit it.
Ive got a spare engine, but it does require quite a bit of work to get it up and running. Head wise it requires 2 new exhaust valves (their bent)
