Fog lamps don't work so... I just took off my front bumper to take a look at my fog lamps but the lamps don't actually open up. Do I have to replace the entire lamp?
Has anyone done this? What is the part # etc; -Thanx.
After considering the situation I reckon the lamps WILL open but they are very rusted and use some obscure screw type.
Can't help you I'm affraid. I can't remember what we did with mine, or how they came apart. Sorry
3 screws on the bottom of the lamp take the bottom off to gain access to the bulb. H3 bulb 55 Watt.
Normally very corroded due to being some sort of alloy housing.
Perfect timing- I'm going to try again this morning.. Thanx. I hope there is enough screw left under the corrosion.
