As suggested, I think it would be useful to a lot of our over seas friend if we could start keeping a record of part numbers.
If you ever get a part from a Honda Dealer, the part number is usually on the part somewhere.
Air filter
17220-P36-010
Bottom end gasket set
06111-PZ3-010
Cambelt
06141-P36-306
Clutch release bearing
22810-p37-013
cover plate
22300-p36-010
Distributer lead, from/to ECU
32723-p36-000
Exhaust Valve
14721-p36-000
friction plate
22200-p36-020
Head Gasket Set
06110-P36-020
Headlamp bulbs
33115-SH3-003
Oil Filter
15400-PFB-014
Oil pan crush washer
94109-14000
Piston 0.5mm oversized
1310-P36-000
Ring set, Piston (for 0.5mm oversized)
13031-P36-003
Roof clip BDR Face (the black ones on the outside of the roof)
91504-SM4-000
Spark plugs
NGK BKR6E-11 or
980795614E
Anymore for anymore?
