Apparently my cam sensor is causing the engine light to go on.
Anyone know the part # by any chance??
Thanx-
Thanx-
I had this same problem.Is the engine checklight flashing 9 times when you do a self diagnostics check to find the fault code.Mine did and after checking the cam belt hadnt slipped a tooth i then rechecked the ignition timing,reset the ecu and no more checklight.
Try this before purchasing a new sensor.
Thanx for the tip I'll double check. -db
