hi , my engine light has just started to stay on , i checked for a code and got 37 , any ideas what this might be and please please dont tell me i need a new ecu ?
BRIAN
BRIAN
http://www.u-ukhbc.co.uk/troubleshooting.htm
although its not there!
ill do it again , but im pretty sure it was 3 long and 7 short .
CHEERS BRIAN
ive just tried to reset the ecu , light is still staying on all the time , on second lokk it is two seperate codes im getting , 3 (MANIFOLD ABSOLUTE PRESSURE (MAP SENSOR)and 7 ,THROTTLE ANGLE SENSOR . im useless at this sort of thing , so any advice is much appreciated .
BRIAN
ps . where is the ecu located , yup thats how useless at this i am .....
ECU is behind the document box behind the passenger's seat.
Thanks Laurance .
i have a spare ecu for sale pm me if needed
hi , i left the beat in to the garage and the lads are still unsure whats wrong , they swapped a throttle body and map sensor over from another civic and no joy , they think the timing belt might have jumped a tooth , or that the dizzy might be playing up , are Beat dizzys prone to trouble ? and will they have to drop the engine out to look at the belt ?
Again how it all started was an engine warning light , showing code 3 and 7 , the car stars fine and ticks over fine , but when you press the pedal it gets very lumpy or just cuts out . any ideas and help is much appreciated .
BRIAN
