I now have a pair of calipers for 262 discs from a crx sri del sol and will find out if they fit later today then just to worry about the discs if they do!
The carrier for the 262 caliper from a del sol might not sit properly centred on the disk as mentioned earlier..
You could get around this by shaving the carrier or putting a small spacer behind the disk.
Hi, I have eventually got round to checking clearances on this 262mm brake conversion, (We hibernated in Spain this year! so things got put off for a while) I have a spare front hub so I can mount it on the bench to get a better view on it, whereas the disc fits and needs spacing by 5.5mm the carrier is nowhere near right and the mount holes are short of lining up by 15mm, do you know if there is another carrier that would fit?
Good Afternoon Folks,
My name is ben from Canada. I'm looking for a pair of DOT/SAE approve tail lights and head lights. Currently my poor beat is in the garage rusting away due to strict regulations inCanada. If anyone could help me find such part or a suggestion on how to make my car drivable again that would help me a lot. thank you for your time..
Sincerely,
ben
Maybe start a new thread next time, but here is what i did:
http://www.u-ukhbc.co.uk/vbb/showthr...-DOT-compliant
Good luck with the inspection Ben, they can be quite picky.
