ECU warning light but no codes
Hi,
My water pump recently ceased and hence damaged all the valves. The engine has been stripped down and rebuilt with new parts from shipped over from Japan and the engine runs and sounds good; however, the engine light came on and gave me a code "9" error (cylinder 1 position). I cleared the code but now the warning light still comes on but does not provide any new warning code number.
I read a thread about this on the forum but it had no conclusion.
Before the warning light comes on fully it seems to partially illuminate and flicker.
I am hoping maybe someone has seen this before and points me in the right direction before I pull it all apart again... I plan to focus on the distributor timing and then maybe the position sensor connectors and engine earth cables.
Appreciate any help
Andy
