Tonneu front stud
Hi
I can't fit my tonneau front stud to the car (the same stud you have to undo when folding the roof).
I want to either change the stud or buy a new tonneau ...
But If I have a look here https://page.auctions.yahoo.co.jp/jp/auction/l404353070 -> https://auctions.c.yimg.jp/images.au...vueop10279.jpg
It looks like the same stud as on my tonneau.
Am I missing something?
If I remember correctly from my first Beat (9 years ago so I may be wrong) Honda used 2 different fittings for the front of the roof. The original was a Tenax fixing that was replaced on later models with a simple stud When I tried to order a replacement pair of fixings (I had the same problem as you) Honda supplied me with the later stud type, the original part had been superseeded.
It sounds like you have a late tonneau and an early roof. The simple solution would be to buy a pair of fixings from Honda (90306-SS1-505) and replace the fixings on the hood.
As fxdlidon says the original fixing are tenax fittings, if you want to get some they are available from the supplier Namrick
http://www.namrick.co.uk/acatalog/Ho...ated__165.html
You would need the machine screw type to fix to the body.
The later fixings are just normal press stud type fixings which Honda now supply.
I accidentally threw away my front fixings with my old roof and, much to my dismay, they are no longer available from Honda :(
So I went with the Tenax option - the standard Tenax studs that fit to the bodywork are 2BA so you need German Tenax Pegs, these are 5mm, the same thread as the originals, and fit perfectly :)
I went to a local car trimmers and he had everything needed for mine. He fitted them there and then and was very reasonable. Whilst there I took a look around. In a corner was a ‘project’. I said is it an old Jag and he said no it was an Aston Martin DB 1. He said it was worth £1m. He said that there were only 2 known and that the owner of this one owned the other as well. Mmm, the ‘project’ actually looked worth a few hundred to me. Rarity and desirability are key. Still prefer my Beat though........
