Engine rebuild underway, need part numbers for bearings
G'day all,
My Beat's at the mechanic's shop at the moment, having suffered a water pump failure ("so that's what that noise was!"). Anyway, I'm taking the opportunity to get the engine rebuilt - I've done OK so far tracking down part numbers, but have now struck the issue of bearings. As I understand it, I need some code numbers from the engine, and these can be used to look up the size required. So far the only code he's found is "CCBC" on the block, I understand there should also be a code on the crank itself - though he couldn't find one. If anyone could help out with locaing the appropriate codes and looking up the corresponding bearing sizes & part numbers, it would be hugely appreciated.
Cheers,
Karl.
