Results 1 to 10 of 10
Thread: Stereo Removal help
    Manchester UK
    Stereo Removal help
    Hi all, does anyone know if a thread already exist detailing how the Gathers stereo comes out without breaking anything? -and also which details the correct cable run for the multichanger lead?(could'nt see anything in the service manual) I'm going to see if my kenwood changer works with it (i read somwhere it should- only discs 1 to 6 are accesible though out of the 10 available on this unit)
    cheers
    shane
    Very Carefully...
    There are 4 screws/bolts that hold the stereo in place, 2 each side sort of hidden behind the carpet.
    Before you start though, have you got very small hands???
    Because you will need then to plug the wiring back into the radio when you put it back and to say it can be a bit fiddly is an understatement...
    And, put the car into 2nd/4th to give you a little bit more room taking it out and putting it back.
    I cheated and mounted my CD changer behind the drivers seat so didn't have to worry about the route too much but I would guess that the best route would be along the passenger side somehow...
    Not sure if the kenwood will work though, I know a lot of the clarion ones do but not sure of the rest...
    Ady.
    Melbourne, Australia
    Stereo Removal
    Hey Sharpen,
    Try this link...
    Stereo Removal
    Hope this helps.
    South Staffs
    Hmm, that doesnt work any more!
    Wonder if i've still got the page somewhere?
    South Staffs
    screw is here!
    Manchester UK
    Thanks Paul that picture probably saved me hours- would'nt have suspected those two screws.
    Well I do have small hands but never thought it'd be that tight. Anyway felt behind the unit for the CD connector and found it in the lower left corner, so didn't have to remove the unit fully to get the changer cable plugged in.
    Sadly, as you suggested Ady, the Kenwood changer is incompatible with the Gathers units so will get one off ebay- there seems to be a good supply of CDC634s on there for ~£20-£30.
    THANKS GUYS FOR YOUR HELP AND SUGGESTIONS!!
    shane
    Derbyshire, Uk.
    I spent a week on ebay trying to buy one... finally found one that i was winning... only to find Jurek had gone and bought it first hee hee
    Damn you Jurek! hee hee
    Paid for one though in the end, hopefully should get that by the weekend.
    Good luck with your bidding, hope you have more luck than me
    Jan 2005
    PETERBOROUGH
    I must say sorry to then !!i bid on a cdc634 the other week on Ebay and won it i think it might have been you who strated the bidding?
    OnE DaY i WiLl gEt ThErE.......
    Derbyshire, Uk.
    D'oh you're all mean to me
    Birmingham UK
    Hi the C-bus cable goes under the carpet on the passenger side then through the bulk head via a grommet just under the seat belt mount . You will see the loom going through it. Then to the left of the engine to the cd changer.
    You dont need to remove the radio as the c-bus plug only goes one way on the bottom left (passenge) rear corner.
    its that easy.
