I have a Honda Today bottom end (very low mileage),
Basically its the same as a Beats bottom end (EO7A aswell) only one of the mounts on the block is in a slightly different place(I think it the one that goes onto the firewall), so a bracket would have to be made up, not a massive job.
The engine is stripped down as I had intended putting it into mine (until I noticed it wasn’t a straight swap) at that stage I decided to rebuild my own since it was out of the car aswell.
It would be ideal for spares... the pistons, crank etc are the same as the beats engine, or if you wanted to do a bore out jobby or something with the block, or even rebuild it...
£50 anyone?? Just want the space in my shed back!
