I have a problem with beat which cants go above 7000 rpm. Now i will tune it again n also go compression n leackage test so first tell me with detail How i do turnning from opening of engine compartment till end in detail. Also tell me the the tappet clearence n each cylinder reading on normal conditon when i do the compression test. How i perform the compression n leakage test. If anyone have any other idea why i dont got full rpm n bad pick n bad fuel consumption tell so i how i improve all. Thanks.
Ali.
