dodgy sound
sometimes when its cold or moist, when i start the beat up, there is a kind of squeaking coming from the engine, i think it may be one of the belts, but i had them all changed!, but if i turn the engine off, and then bak on, it stops. anyone any ideas, is it a problem or should i just live with it?
You got it there, its most likely that the belt is a little loose making a noise. They only do that when its moist. Take off the rear engine lid and tighten it up.
Mine does it too, but seems to be ok once it's warmed up.
