Results 1 to 8 of 8
Thread: Door Pin
    Nov 2006
    Door Pin
    I wonder if I can get the little door pin that turns on the interior light when you open the driver's side door. I think it's a small plastic bit.
    Anyone have an idea?
    It would be a new switch. CRV 97-01 model ones are the same fitment.
    HTH
    Nov 2006
    switch
    Thanx. I'll look into that. Seems like the best way to alarm both doors.
    Is there any other way?
    Just add a switch to the passenger side door, run the wire to the drivers side switch. will cover both door then.
    Nov 2006
    switch
    Thanx I'll give that a go. Hope to find the switch soon.
    Ipswich
    That's exactly how I did mine, Worked fine that way.
    Ady.
    Dec 2004
    Birmingham UK
    I went to scrap yard and got the switch from an old civic most mid 90's Honda used the same switch.
    Hope it helps.
    Nov 2006
    switch
    Thanx-picked up a switch from HONDA today thanx to Steve M. info.
