Ive a problem with my beloved beat.. It’s only running on two cylinders. Cylinders one and three are ok but cylinder 2 isn’t doing anything.
I decided to take a closer look.. One of my new performance HT leads was broken (cylinder 2). It looked as if the lead had melted where the wire meets the sparkplug connector so when I went to take off the lead-it broke. I decided to put back the original leads, because now one of my performance leads was broken, one of the performance leads never sat right and the RFI ment I no longer had a radio.
After a change of spark plugs and after putting back on the original leads the same thing is happening. I decided to take the ht lead off cylinder 2 and there was a fairly healthy spark out of it.
Another thing I noticed was that when I removed the spark plugs the one from cylinder 2 had more oil on that the other two.
Would I be right in thinking the rings on cylinder 2 could be damaged? That could explain the oil on the sparkplug and maybe the ht lead was delivering a spark and it only broke when i went ot remove it.
Any ideas anyone? Thanks
2 Cylinders
