Thread: AC not blowing cold
    marcair Guest
    AC not blowing cold
    Fan works fine. Where are the AC fuse(s)? Or any suggestions as to troubleshooting? I did not have time today to study further. If you mention a component, please add location info unless it is obvious.
    A couple weeks ago, I turned the sys on and it worked fine.
    Thanks in advance.
    Dec 2005
    Cirencester
    Have you been using the aircon regularly?
    if you dont turn it on for a few minutes every week the seals dry out and you lose all the gas. Thats a $100 dollar fix over here.
    I love the smell of Nitrox in the morning !
    1992 Beat
    2000 Seicento Sporting
    2000 Landrover Freelander to tow them home with
    You should get a clonk from the back of the car when A/C is switched on if the magnetic clutch on the compressor is working. If this happens it probably needs regassing
    marcair Guest
    Location of the AC relay, anybody? Under the dash, or?
