Can I get a blank from anywhere so I can neatly do away with the Gathers O/E stereo? I want to eventually install an amp, speakers and Ipod dock. Not sure I want an hole in the dash.
Get yourself a centre console from a car that has not had a stereo fitted as there will be a pocket/box in its place that is cut out when radio is fitted.
Why don't you fibreglass and fill the hole yourself? Especially as your now painting all the interior trim, all the colour matching issues don't exist!
<<<<<<<VERSION Z>>>>>>
>>>gone, but not forgotten<<<
I was unaware they came without stereo's? Must have been a type-R version If someone could source a part number, that might be the cheapest way to go, even from the stealership...if you don't want to mess with fiberglass anyway.
I found a nice kit on yahoo auction for a doubleDIN replacement so you can put a regular doubleDIN stereo in place of the factory Gathers unit. It included the entire surround where the air controls are in. I'll post when I get home tonight,
I'd better place a wanted ad.
Check it out. Last pick is part #
@ Mylee, I have never tried fiberglass.
I think I will try to find a consol with the pocket.
Looking at what you've done to your Beat, fibreglassing is well within your capabilities!
I would also like to find the original shelf that exists if no radio is in the BEAT.
If anyone knows about this please inform. -Vancouver, BC
Further to fabricating a blanking plate, consider:
Abrade the surface of the console that will be overlapped with the plate. Size a sheet of 1-2mm thk plastic to fit over opening and align with a ridge or other contour change to help with blending. Chamfer the edges. Secure the plate with a rubberized adhesive. Allow to cure. Apply autobody fender paste / putty with fingers to blend the plate edges to the console. With the paste / putty still soft, add texture with a brush, rough sponge or whatever works best. Handsand. paint or cover with fabric.
