Results 1 to 12 of 12
Thread: Additional speakers and sub
    So I thought that a few more speakers, along with a new head unit and a sub might help the weak stock 40 watt unit.
    I found a few surplus speakers and covers that
    i had, and trial fitted them
    Make a template with the speakers you got and trace it out to an aluminum sheet, (or wood, sheet metal etc.)
    Then fabed up the "cabinet"
ID:	1637   Click image for larger version.
ID:	1638   Click image for larger version.
ID:	1639   Click image for larger version.
    Wire it up, spray glue and vinyl, with an automotive plug disconnect and drop it in to place.
ID:	1643   Click image for larger version.
ID:	1644   Click image for larger version.
    Soon to be fastened down. Then I added some dash tweeters for brilliance and some two-way 6.5 inch door speakers.
ID:	1646   Click image for larger version.
ID:	1648   Click image for larger version.
    Then to finish with a thump, at least when at a meet or on cruse night, this 200 watt, 12 inch shallow driver fabbed into the spare. Two amps, one for the rear deck speakers, and one for the spare sub are in the trunk, next to the battery. The head unit is next, a JVC mp3 unit with aux and usb in. Just gotta wait for the weather to thaw before doing the dash work. B.
ID:	1650   Click image for larger version.
    Never been a fan of subs under the bonnet, but the ones on top of the engine cover are very nice. Good work (and that's from someone who used to build sound off cars )
    bigB, very nice job! Again, you could sell that stuff you are making! Looks OEM good! I bet that your Beat has a nice beat now with all those speaker!!!
    Feb 2009
    Ottawa, Canada
    That's a really nice job on the speakers in the back! Congrats! I'm not a fan of sound systems but that sub in the front is propably gonna surprise lots a ppl
    Sep 2007
    Clean work BigB.
    email me (previous address) with your address and I'll send the tonneau
    Done!....
    Finally finished the fiberglass work for the dash and the single DIN.
    sub+rear deck amps with cooling fans
    pounds like "your son-in-law's civic with a fart-can".... lol....normally I don't crank it up because with the sub its just as loud standing 6 feet from the car, as sitting in it. An added engine cooling fan to help out...some lexan... and spun a new oil cover. I could use suggestions for a fan thermostat?
ID:	1843   Click image for larger version.
