Beat accerating very slow and not able to go above 4)mph
Hello
My beat is accerating very slowly and I have to change up gear every 5MPH ish.. it feel like the speed limiter have kicked in even at 1st gear. and further more I can not do anything able 40MPH, even in 5th gear?
I have recently had the ECU fix by ECU doctor.
Does anyone know the case of this and how to fix it?
thank you .
I wouldn't be driving it at the moment if that's the case, could cause permanent damage.
You need to do an engine code check, in the engine compartment is a yellow connector:
http://u-ukhbc.co.uk/vbb/showthread.php?t=1448
Can you give more information.
Like is it reving right when not in gear? Any ECU codes like Wh1teLeopard said?
Why was the ECU at the Doc?
I have a dream
Clutch may be slipping badly if revs are up high with no groundspeed.
