Thread: Want a passenger door switch?
    Went to the wrecker today and got a few. Free for the asking
    Run a single wire to your other door switch wire, and you're good to go. A must have for an alarm or added interior lighting.
    Quite a few older Honda models had the same switch - CRV 97-01 for example.
    The only thing your find missing on the door jam is the thread in the hole for the screw.
    When I fitted one I scratched away the paint behind and used an earth type spire nut (so it dug into the bodywork behind the hole) and a self tapping screw.
    And as you say run a wire across the car to the drivers side switch.
    Sep 2007
    One step further, tap off the hot wire of the driver's side interior lite and run into the pass lite assy.
