Originally Posted by
nalobcram
can anyone advise please???
also have a problem with the air con.... it was regassed last year too... but now the compresser isn't cutting in and out... is there a fuse for this??? i've been in the fuse box but everthing is fine... i'm reluctant to spend any more money on this car at the moment
any help thankfully recieved....
If you bridge the pressure switch that can be found in the pipe at the front of the car near the condensor that should make the compressor run with A/C on, it will then signify if there is any gas in the system.
