Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: Tyres. Again.
    Sep 2009
    Tyres. Again.
    Hello.
    I've searched the various tyre threads on here and there doesn't seem to be any 'final word' on Beat tyres for standard rims.
    I'm pretty fussy and want decent/ correct tyres on my car, the only H rated front tyres I can find on the UK market are Kumho which don't seem to be rated very highly.
    Bridgestone Japan recommend these
    Anyone here ever imported tyres to the UK before?
    I've sent out a few emails for quotes, but if anyone knows the best way to go about it has any tips or advice it'd be appreciated.
    May 2009
    Edinburgh
    These people have the correct tyre sizes, a decent choice and reasonable prices http://www.camskill.co.uk/ I have used them and had no problems.
    Tom
    The Beat goes on ......
    Sep 2009
    Cheers but the thing is, having tyres with the wrong speed rating can void your insurance as far as I know. Which appears to mean budget tyres only for the front.
    I also got in touch with Bridgestone europe who advised me not to use the wrong rated tyres regardless of the difference in the cars top speed and the rating of the tyre.
    Rochester, Kent
    Kumho's have been fine on my Beat since I imported it over 2 years ago.
    I don't do tracks, I don't race, and my Beat is just a summer toy - may be different if your driving all year round.
    <<<<<<<VERSION Z>>>>>>
    >>>gone, but not forgotten<<<
    Quote Originally Posted by ANOBOBOLOUS View Post
    Any tyre you import from Japan that was not intended for European market will not actually comply to EU legislation as it wont have th 'E' Mark on them.
    You will find it difficult to get the correct speed rated tyre for a Beat, as its not a common size for UK. Main use for the Front size is Metro.
    Try http://www.event-tyres.co.uk/
    They have some good makes - Dunlop, Toyo, pirelli
    But they are all 'T' rated. for 155/65 13
    Some 'H' rated for 165/60 14
    Oct 2007
    Halifax, Canada
    OEM Tyres
    Does any one know what the original tyre make amd model was then the cars were new? I suspect Bridgestone somthing or others.
    These might be an option as these were what was designed for the car as OEM types.
    Steve
    Beat Red
    Halifax, Canada
    1991 Honda Beat
    1965 Honda S600 and
    Honda Lawn Mower
    Jun 2007
    Camskill are good for tyres, a good selection, competitive price and excellent service. T's are rated to 118 mph so are fine on the Beat.
    Fronts
    http://www.camskill.co.uk/products.php?plid=m4b0s369p0
    Rears
    Sep 2009
    The tyre place I took it to reckon that the Bridgestones that are on it are the originals! They're K'grids all round, rotational, made in japan and they're starting to crack up.
    I figured if it passed the tests on the way into this country then japanese tyres must be ok, although the rules may well have changed since. I'll check the tyres in the morning and see if they have an E or the DOT marking on them anywhere.
    May 2009
    Edinburgh
    I dont think the fact that it was successfully imported means the tyres are legal in UK. That is the responsibility of the driver, not customs officials - imho. The specs I have do list H rated tyres but I would concur with Beardo's view that T rated should be perfectly sufficient but it may give you piece of mind to check that out with a tyre specialist, I am sure Camskill would keep you right ;-)
    Tom
    Yes I would agree with that, and they will be way past there best by now.
    There are quite a few items on a Beat, because it is a Japan model only are actually not homologated for EU use, but because these vehicles come in under SVA test, its a bit of a Loop hole.
    A quick trawl on the net suggests the lowest rating,"N", is suitable for speeds up to 87mph or 140kph which I believe is the maximum speed of an unmodified Beat. As far as I'm aware there is no problem using tyres of a higher speed rating than specified but you must not go lower.
    May 2009
    Edinburgh
    Given that the maximum speed limit in UK is 70mph then surely all tyres rated above 70mph must be okay for use here Would an insurance company then have to prove that the vehicle was exceeding the manufacturers limit to nullify a claim?
    Tom
    May 2009
    Edinburgh
    Quote Originally Posted by LawrenceHarding View Post
    My copy of the Honda specs, I don't know if it is the official one, but it does quote H rating despite the speed rating being well in excess of that quoted for an unmodified car. Anyone know why that should be the case, if it is indeed the official line? FWIW, the parts list also specifies H rated tyres!
    Tom
    Quote Originally Posted by Bumbly1 View Post
    The Honda specs that I have a copy of do quote H rating despite the maximum speed being well in excess of that achieved by an unmodified car. I wonder why?
    Tom
    Its not just to do with the speed. A relaventr speed rating will come wil a Load rating as well.
    This gives a tyre a certain stiffness/performance. A vehicle will be Homologated relavant to that specific tyre type/size etc.
    In some countries un like UK. for those countries annual test (MOT) they cannot have incorrect speed rated tyres. This has become a problem on Integra Type R, as Bridgestone have decided to stop production of the only spec tyre there was.
    May 2009
    Edinburgh
    Quote Originally Posted by Steve_M View Post
    I understood that the load rating is the two (or three) numbers prior to the speed rating letter.
    Tom
    Sep 2007
    this site may be informative:
    http://www.1010tires.com/tech.asp
    Quote Originally Posted by marcair View Post
    From this website.
    "It is also an indication of how the tire will handle at lower speeds. A higher rated tire will give you better traction and improved steering response even at 50mph."
    Thats the reason a Beat has OEM tyres that are 'H' rated. Not that it can do 130MPH.
    When I had my Beat I had 'H' Rated Continentals on the rear and 'T' rated Firestones on the rear. I did 3 track days at Castle Coombe and quite a few long trips with no tyre issues.
    Sep 2009
    Cheers folks, all useful information.
    Steve, if it handles well enough on a track day...
    I'm no racing driver but I do drive it fairly hard from time to time. The drift is half the fun. It just doesn't fill you with confidence when everywhere seems to say "don't use anything other than OEM spec tyres" and "don't mix speed ratings"
    I couldn't see any E or DOT markings on the outer wall of my current tyres but I'm fairly certain they had a DOT mark embossed on the inner wall when the wheels were off.
    we imported a pair of advan a048s for ours a couple of months back - it wasnt actually that expensive at all. we sent em by sea which took about 8 weeks - it worked out at about 25 quid more per tyre including jesse's commission fee and you can get the perfect size.
  20. #20
    Sep 2009
    Thanks Tado,
    I've already got a quote from Jesse, it's not too bad either.
    With regard to 'E' marks on tyres, here's a quote from bridgestone:
    "As far we’re aware the non-E marked cannot be sold in the UK under the Sale of Goods Act. We’re not aware of any legislation that forbids the use of non-e-marked tyre on UK roads"
    interesting.
