Thread: Open trunk / boot help!
    Jun 2009
    Hull, UK
    Hi, just been checking the spark plugs, and have closed the boot with the only key to the vehicle inside it, is there any way to ge tinot my boot other than ordering a new key (which I need) or getting locksmith? I need to know quick as the windows are down and it's parked on the street! what a stupid thing to do......
    just thinking round it, im pretty sure there isnt!
    pretty sure all other access is blocked! have you tried calling a local locksmith? sure they must get this happen quite often.
    Mar 2007
    Paderborn Germany
    Maybe i can help you. The easiest way is to order a new Key from a HONDA Dealer. What you need ist the keycode. You can find the code stampt on every Keycylinder. In Your case is it the easiest way to remove one door cylinder, read out the Code, which has 4 numbers. Hope i could help You.
    You meet the nicest people in a HONDA!
    I will send you a PM there is an easy way to get into the boot.
    Jan 2014
    Adelaide, Australia
    Care to share Steve? This is my biggest fear with the Beat... really should get a 2nd key cut!
    Quote Originally Posted by Pav View Post
    Pav, Ive sent you a PM.
    Jul 2008
    Dublin Ireland
    I'm intrigued Steve ??
    I managed to lock 2 sets in boot at Rockingham a couple of years ago...oops!!
    Phone call to the AA.…...it involved a small air pump,plastic wedges,thin ratchet spanners, a patient mechanic and a disclaimer from me reference any distorted panels/boot lid.
    It all went back OK luckily and i now leave the key in lock whenever the boot is open
    The are usually key blanks for sale on Japan Yahoo.
