Thread: wheel arch plastic plug thingys needed
    bit of a long shot and a random request, but does anyone have a pair of the plastic plugs/bungs that go in the hole in the front wheel arch and allow you to get to the sidelights? ours somehow got lost between the bump and the repair.
    its the round plastic plugs that go in the holes shown in the attached pic.
    if anyone could help that would be great, if not i'll get em ordered. ta very much indeed!
    mike
    May 2007
    Swindon
    If you have no luck with the parts required, try you local electrical shop for electrical panel bungs.
    thanks for the tip rod!
    May 2009
    Swindon
    I know of a Beat going due to the scrapage scheme.... no promises, but see if the owner will part with the seals before the car is handed over.
    that'd be great thanks! sad to hear about the one going in for scrappage tho
    Looking at the parts catalogue. I think this is the correct parts.
    Are the for a 40mm hole??
    If so 91616-SS1-000 and they are £1.92 each inc VAT.
    Also used on a 92/93 CRX (in the rear panel)
    a 98, 99, 2000 Integra (in the floor under back seat)
    a 98, 99 Shuttle (in the boot floor)
    thanks steve thats brilliant. i'll get the tape measure out and double check but 40mm sounds about right. much appreciated!!
