Thread: Troubleshooting - Dead rev counter
    Jan 2003
    Cheshire
    I wonder if anyone else has seen this problem. My rev counter is completely dead, all other dials in the pod work fine, all lights are okay as well, just the rev needle stays at zero. There doesn't appear to be a fuse just for that dial and all connections into the pod seem good. Any suggestions?
    Colin
    Pulse for tacho comes from coil via blue wire. so check connection at the coil. check continuity of this wire back to gauge assy.
    Gauges are powered by 10 Amp fuse. L/H row 2nd one down. (but if other gauges/warning lights work then thats ok)
    Wiring diagrams HERE
    Jan 2003
    Cheshire
    Thanks for the reply Steve, I'll go hunting blue wires tomorrow. Now where did I put that multimeter...
