My mechanic has managed to read the codes from the face of the crankshaft.
OK, so I've got "CCBC" on the block, "222" on the rods, and "CDC 3222" on the crankshaft.
If I'm reading it correctly, that gives us main bearing sizes: brown, green, yellow, green (respectively).
I take it there's a similar look-up table for big-end bearings also?
Karl.
Your correct as far as how I interpret it.
So shells you need.
Main Bearing shells.
Brown = 13323-P36-003
Green = 13324-P36-003
Yellow = 13325-P36-003
Dont forget you need to order 2 for each bearing (sold individually)
Big end shells
You need a 2C , 2D and a 2C = Green, Brown, Green
Green = 13214-P36-003
Brown = 13213-P36-003
Same again as Mains, sold individually.
Thanks Steve, much appreciated.
Karl.
glad you're getting somewhere karl. you were definitely right about the water pump too - ours was swapped out on thursday and you can hear the old one squeak every time you turn it - and there's a definite stiff spot in it. phewf.
Just resurrecting this old thread as in the process of an engine rebuild if someone can help please with which bearings we need please
On my engine I have got "CCCC" on the block, "222" on the rods, and "BCC 2322" on the crankshaft.
We are trying to translate / decipher the manual and a 2nd opinion would be great.
Many thanks
Crank bearing
1. C2 = Green (D) = 13324-P36-003 x 2
2. C3 = Brown (C) = 13323-P36-003 x 2
3. C2 = Green (D) = 13324-P36-003 x 2
4. C2 = Green (D) = 13324-P36-003 x 2
Big end
1. B2 = Yellow (E) = 13215-P36-003 x 2
2. C2 = Green (D) = 13214-P36-003 x 2
3. C2 = Green (D) = 13214-P36-003 x 2
From these:
https://drive.google.com/file/d/11GS...ew?usp=sharing
https://drive.google.com/file/d/1Y2W...ew?usp=sharing
Regards
