Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
Thread: Fujitsubo Exhaust questions
  1. #21
    Sep 2007
    Put the car on jacks and run the engine in an echo chamber (garage). An exhust leak should be quite easy to identify. If it is not an exhaust leak, try slowly starting in 2nd or 3rd gear and listen to the engine. Any internal issues will become apparent.
    The right fender inlet only vents the area aft of the gas tank.
  2. #22
    Mar 2007
    Paderborn Germany
    For those guys who don`t know this video, this is my inside sound. Fujitsubo exhaust and 35mm funnals fitted, no speed lim., 3Km Autobahn.
    http://www.youtube.com/watch?v=yDExF3d_3jA
    Iloveit!
    You meet the nicest people in a HONDA!
  3. #23
    that sounds an awful lot like our mugen too. we even have the same engine cover and throttles!
  4. #24
    Quote Originally Posted by Guido View Post
    Iloveit!
    Sounds WAY better than stock. I want one!
  5. #25
    Yay, won a used one on Japhoo last nite. Looks like it has some custom tailpipe hangers.
    https://picasaweb.google.com/lh/phot...eat=directlink
  6. #26
    I'm just getting around to mounting the exhaust I bought (above post). There are 2 bolts holding the stock exhaust heat shield on the bottom lip of the bumper, and I wonder if I should use them for the rubber hanger straps that can be seen in the photo above. The hangers are about 70 cms apart and the bolts are 65 cms, so the hangers wouldn't be exactly vertical.
    When I hold it by the hanging bars, it feels very well balanced, so those straps wouldn't be carrying much weight.
    Does anyone else (Guido?) have one of these Fujitsubo 4-pipe exhausts now?
  7. #27
    Sep 2010
    Wellington, New Zealand
    Thumbs up
    Nope, but my custom made exhaust made a huge difference to the car. I'm sure you must be itching to take yours for a spin once it's done.
  8. #28
    It sounds fan-great-tastic! Actually it's a fair bit quieter and mellower than stock. I took it through a tunnel at speed to get the full sonic effect. Might have a little more kick around 5-6000 rpm (specs claim +4 bhp). I didn't realize how tinny the stock unit is until having it off the car, which probably gives it that cheap tone.
    Only problem is that the Legalis K hangs quite high, with the tailpipes just about touching the bumper lip. Those oddball hangers are now attached to the chassis with angle brackets, so it's very secure, just doesn't look quite right.
  9. #29
    Sep 2010
    I have a couple of tunnels locally that I love driving through for the sound effects. I'll often back off from the car I'm following so I can give it some revs going through
    Any photos yet?
  10. #30
    Fujitsubo Legalis K
    It's not that big-bore look but I'm liking it more and more now.
    I have not actually cut the bumper (yet) - the "cutouts" are bits of black tape
    https://picasaweb.google.com/1159014...CL3wqOSq8M-JLw
  11. #31
    Sep 2010
    Looks great if you ask me, although I do see what you mean by being tight to the bumper. I'm sure if you cut where the tape is it'll be mint.
