Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
Thread: Increase in top speed
  1. #21
    Quote Originally Posted by Gavin View Post
    Doing a turbo conversion would actually be that hard on these it was always something Jen looked into before she went with the other option
    What option was that?
    It's certainly true that there are loads of parts available from the many turbo Kei cars. Anyone ever jammed them into a Beat?
  2. #22
    May 2009
    Vancouver, CANADA
    There are quite a few people in japan that have turbo'd the beat.
    I found some on the minkara site. Just run them through google translate.
    http://minkara.carview.co.jp/userid/...233/photo.aspx
    http://minkara.carview.co.jp/userid/...7/profile.aspx
    I was considering a turbo as well, but the hard part was finding an ecu control unit. Most people in japan used MoTeC. Then again, most people in japan had blown up their engines...
  3. #23
    Quote Originally Posted by maiku View Post
    Hmmm. interesting. I have the time but not the skills. I need a better translator too.....
    "The kangaroo bar of [karutei;na] is cut off to the turbine from the back of the octopus foot, and the drum is 60 pie muffler for [mirata-bo]. "
  4. #24
    I'm using an Adaptronic e320c in the AZ-1. It's replacement the Adaptronic 440 would work well to set up and run a turbo on a Beat
  5. #25
    Dec 2005
    Cirencester
    Quote Originally Posted by bigB View Post
    brucebp, how about a supercharger for your beat? 110hp. you could accelerate to 140km/hr (speed limiter) instantly to pass!
    http://speedhunters.com/archive/2011...onda-beat.aspx
    You got me thinking, the Cappo has a suitably small turbo doesn't it?
    But.... I'd still be up against that bloody limiter.
    I love the smell of Nitrox in the morning !
    1992 Beat
    2000 Seicento Sporting
    2000 Landrover Freelander to tow them home with
  6. #26
    Mar 2009
    Shropshire
    thing with doing a turbo conversion is you will need to get some sort of uprated clutch that will cope with the extra torque you would kill a standard clutch within a few hours.
    I think doing a turbo conversion on a beat would be pretty easy and could be done for a good price aswell it is just a case of how much you want to actually spend doing it? Bike engine conversion would be good but again price of doing that is huge even doing it yourself I mean Jen has probably spent in the region of 6-8k? at a guess so far and she ain't even near finished yet.
    I think with the beat a top speed of about 90/100 is enough but if you generally don't go above 80/85 and want a bit more ooommpphh to overtake stuff then turbo conversion is something to think on. Small turbo like a ihi rhb51 vq10 or vq12 off a charade gtti would work quite nicely
