Results 1 to 10 of 10
Thread: Aftermarket Headers...
    Jan 2009
    Anyone actually run aftermarket headers on their beat?
    If so, did it delete the cat/o2 sensor?
    What brand/model are you using and how do you like it?
    May 2009
    Vancouver, CANADA
    I got stainless steel header from yahoo, i can't recall if it came with the O2 sensor bung, but my mechanic had a new cat put in with the O2
Name:	Exhaust Manifold 140955276.jpg
    Jan 2009
    Quote Originally Posted by maiku View Post
    Thanks Maiku. How many YEN was the header?
    Was the cat specific for the Beat, or sourced in Canada?
    Do you have any dash lights on (warning lights)? If all warning lights are off, then I'd imagine they must have put a new O2 sensor in?
    May 2009
    Vancouver, CANADA
    The header was 17,500 yen, quite a good deal.
    My mechanic just took a universal cat for mid-size sedan and crammed it in, along with a new bosch O2 sensor
    No codes related to the cat, and my emissions testing was ridiculously low
    Jan 2009
    Good to hear. You don't have the sellers name or brand of header? Most headers I'm looking at were about 30K yen.
    Do you have aftermarket exhaust as well with the header? If so, which one?
    Any power difference with the new headers from stock?
    Jan 2009
    I was going to get mine from these guys...
    http://www.automac.co.jp/parts/parts01.htm
    Along with their center mounted exhaust.
    May 2009
    Vancouver, CANADA
    It was a generic seller, the sale expired so I can't see who the seller was
    They like to refer to it as an exhaust manifold instead of a header
    I got the HKS dual exhaust for the beat
    The one thing I've noticed with the stainless manifold on my AZ-1 is a dramatic increase in engine bay temperature - stainless pipes just don't keep the heat in as well as the original cast iron item although the exhaust flow is better. I don't know if this would be much of a problem on the Beat but thought it worth mentioning.
    It's a major issue on the AZ-1 - the air outlet pipe from the turbo runs very close to the manifold and the air inlet temp has increased dramatically. I just wish I'd had it ceramic coated before I fitted it, they dont stay shiney for long anyway.
    heat-wrapped mugen header with stock cat and mugen exhaust on ours. sounds very nice, quiet up to a point and then howls nicely.
    had one of these fitted too but removed it as my other half grumbled about the smells coming into the house when i was backing up onto the drive
    http://translate.google.com/translat...ory%2Fa06.html
    May 2009
    Vancouver, CANADA
    Yah, tell me about the sound.
    I get a bit of droning around 4000 rpm with my headers, it gets louder as I add more gas
    Could also be the exhaust
