Thread: Fusion fascia build.....
    after promising myself for close on 2 years, well probably more , finally decided to start it.
    refrigerated vehicle insulated panel as a base, bit of shaping, filling, sanding, more of everything again i ended up with this....
    still needs finishing, bit of black foam or similar to finish gaps to plastic surround but you get the idea of final look.
    USB panel mount fits just nice underneath, ideal for the thumb-sized stick i use.
    now just need to decide what to do with the scratched plastic, the result of the hundreds of times the HU has been in and out over the years, but i like to use the car not look at it so probably won't gety done just yet
    Sep 2010
    Wellington, New Zealand
    Good work. Neat idea have the USB port so easy to access.
    Coconut oil works wonders on the scratches. Needs to be reapplied now and then but eventually builds up.
    I fear that they're a bit far gone for that, thanks anyway.
    I vaguely remember seeing something about Peanut Butter as well, or the oil from it?
