Results 1 to 8 of 8
Thread: Dying interior plastics black
    Jul 2008
    Dublin Ireland
    I'll be giving this a go over the next couple of weeks , I'll get some before and after pics etc and do an update as I go along .
    One thing , any thing it need to know about removing the Dash , straight forward or a nightmare ??
    Jul 2008
    Dublin Ireland
    ive found this thread
    http://www.u-ukhbc.co.uk/vbb/showthr...rbish-Interior
    Does anyone know roughly how long it takes to remove the dash ??
    couple of hours should do it easy, try and mark/keep together what fixings go where or take pics.
    Jul 2008
    Dublin Ireland
    Weather permitting ill be doing this today .
    Cheers
    Jul 2008
    Dublin Ireland
    So between rain visitors and my loosing patience i got this done today , it went fairly well but i could have done a better job due to rushing it in the end .
    i started on the door cards and split them as i only wanted to dye the bottom , which you can see is easily done by removing 8 screws , i also remove the
    center piece around the ash tray and hand brake and started work on these , i used a good detergent to remove any ols silicon cleaning products etc , then
    rubbed in the primer and allowed it to dry for about 30 mins , applying the actual dye is easy , spray it on and rub gently in with a cloth , let dry fully and give a
    second coat . It all kinda went wrong when it started to rain and i was delayed by hours with visitors , so i did the rest of the dash and center console without
    taking them out of the car , application was a bit messy and i applied the second coat too soon , so it started to lift the first coat , hopefully it will all dru ok ,as even now its looks quite well .
    BEFORE
    AFTER
    Jul 2008
    Dublin Ireland
    DOOR CARD
    Original old Honda Pioneer speaker
    Wow - it looks great. Just a subtle colour change but it made a big difference. Now, what was the product that you used? And have you ever tried to dye the steering wheel cover?
    Jul 2008
    Dublin Ireland
    Yeah it does look 100 times better , more modern , as to what i used , i wont even post its name as its not what i wanted to use and i think its going to peel , it was a 2 stage product , primer then dye which turned out to be more of a paint .
    This is what i wanted to use but they wouldn't post to NI and wanted £40 to post it to Dublin .
    http://www.vinyldye.co.uk/All-Vinyl-Dye-Color-Sprays
    I will wait and see how mine works out , if im not happy ill strip the interior from the red Beat and start agin , when im better prepared etc .
