Results 1 to 8 of 8
Thread: Not revving passed 7000rpm
    Sep 2014
    OK, just replaced the engine in our Beat.
    Runs fine, but will not rev beyond 7k. Done timing, checked TPS, Map
    No engine codes.
    Any ideas?
    Never got to the bottom of the 7000rpm issue which was experienced on quite a few cars.
    http://www.u-ukhbc.co.uk/vbb/showthr...hlight=7000rpm
    Sep 2014
    Thanks for the response. Well that is frustratingly reassuring lol At least its likely not to be a duff engine
    Will try ECU next
    It does sound like some kind of ignition limiter - rather than a fuel cut/limit
    Ignition coil? Or some fail safe limp mode maybe. Will continue......
    7k in all gears or just 5th?
    Sep 2014
    Quote Originally Posted by Gavin View Post
    Sorry for the late reply!
    yes all gears
    Try this carefully will it go beyond 7k in neutral?
    Jul 2005
    Camberley
    I've just had a quick look at the Japanese sites for this problem. Couldn't find anything obvious, except one person who was complaining about the same problem and was fobbed off by the garage he bought it from ("its old, they all do that, you don't want to go that fast anyway..."). One suggestion to him was that it was the ECU. You might look to swap the ECU with someone to see if this is it.
    I tried an ECU on a car with this problem and it didn't fix it.
    I'm beginning to wonder if it relates to the drive gear on the camshaft, as other cars that were affected I believe had all had cambelt/distributor failure previously.
    Do you know if your car may have had in the past?
