Will be similar to the above Paul, price wise will double check tonight as got a few sources I can order from now
Thats great if you can Gavin thinking of doing the lot on the Red Beat
Major Service kit as follows
Rocker Gasket
Timing Belt
Both tensioners
Both Oil seals
Water pump
Alt & AC Belts
All in delivered would be £165 + whatever percentage paypal fees are all parts are the same I am using myself for my rebuild.
Looked up OEM air filters and Oil filters those are better from Honda direct as you'd only be saving a few quid most there same with spark plugs.
Aftermarket HT Leads full set of 4 £85 + paypal fees
ECU's and Distributors are still available but prices vary.
suspension, mirrors and flaps need to go open to offers on them
Original Honda badges front and rear, front is brand new and rear used. Rear will need cleaning to get the tape off the silver bits but otherwise all good lugs are perfect just apply your own double sided tape and presto good badges. £25 delivered.
Aircon pump no long needed spare unit £35 delivered
