Results 1 to 20 of 20
Thread: S2000 seats? will they, won't they?
    Jan 2015
    a Friend is selling two seats from his S2000 does anyone know if these would cram into a beat or are they just too dammed big?!?
    highly unlikely i'd think.
    Beat seats are different sizes, passenger side is narrower.
    let us know if you manage it
    Jan 2015
    yeah, the beat is just too tiny! nice dream for a short while though.
    Jan 2015
    Hmmm I have recently seen the deft design Craft Beat http://www.deft11.jp/beat/index.html and they have used S2000 seats in there so I have asked for the seats they have been given and now I can play to see if I can get them to fit!
    Fingers crossed it'll be a little while I have a few other bits to do first but I will keep you posted.
    Mar 2009
    Shropshire
    S2000 seats do fit seen a few in Beats over in Japan, seen Civic EK9 Recaros and Integra DC2 Recaros fitted as well, squeeze on the passenger side but they do go.
    Jan 2015
    oh, great news! I was just going to get them and do whatever it took but now I know there are a few like it I'm really pleased can't be too big a job. I hope.
    Mar 2009
    Shropshire
    Don't get me wrong it is a squeeze and a half but they do go
    Sep 2005
    Hong Kong
    Quote Originally Posted by Gavin View Post
    Any idea what seat bracket is used for the DC2 recaros or s2000 seats?
    Aug 2015
    Tohoku, Japan
    The Recaros should be SR4s or something. So they should be bottom mount. Get a plate cut out and drilled, and you should be able to bolt them to your existing rails. Not sure how the S2000 seats are mounted to the rails.
    Jan 2015
    Excellent! is this your beat Gavin? if so was there much modification required? any info would be greatly appreciated.
    Mar 2009
    Shropshire
    Not mine one of the few I've seen.
    tbh the way you'd probably go about it is how Aaron said get plates welded to the oem seat rails bolt seat to that job done, plenty of second hand dead seats about to.
    Jan 2015
    yeah I guess once I have them it'll make more sense. cheers anyway. still got a fair way to go before I worry about those just yet.
    Aug 2015
    Tohoku, Japan
    Actually, I took a look at the bottoms of the seats when I pulled out my carpet. IIRC, it looks like the seats are undermounted to the rails as well. In theory, you should be able to weld some nuts to the plate, and use some shorter bolts. (You might not even have to do that, depending on the mounting holes for the Recaros are.) That way, you can go back to stock, if you're ever inclined to do so.
    Jan 2015
    Well I have the seats and I'm butchering the runners etc to get them to fit but so far so good I'll post some pics soon. But it seems to be going ok on the drivers side. Seats are a bit tired but I'll clean the up properly once I've got them properly fitted
    Pleased.
    Jan 2015
    Ok drivers seat is in and looks great still got to clean it up but love the look of it. The hard part now begins. The passenger side is 2" narrower therefore fitting the huge S2000 seat will be a real challenge. Should be fun getting it to squeeze in but I'm confident it'll go. Lots of fab I think but we'll see.
    Aug 2015
    Tohoku, Japan
    What'd you have to do to the runners to get them to go in?
    Jan 2015
    The runners on the S2000 seats? We took everything off. The only remaining part was the original sides as these keep the seat together. I then welded the Beat seat frame to the underside of the S2000 seat after cutting off any excess metal.
    The drivers side was actually quite easy, the passenger side you have to be prepared to fix the seat back as space is so limited. it's incredibly tight! I have managed to get the seat adjustable forward and back but there is rubbing on the centre tunnel. I will take some pics this week end and show you how they look. overall I'm really pleased with them I just need to clean them up and then I can move on to more interior fun!!
    Jan 2015
ID:	2608Click image for larger version.
ID:	2609Click image for larger version.
    As you can see it is very tight on the passenger side. The seat will be in contact with the door card but thems the breaks I guess.
    Aug 2015
    Tohoku, Japan
    Looking good! Would you have happened to have taken some pictures of the process? I'd love to see what you did.
    Jan 2015
    No I'm not that organised. I've got to take them out again. I'll show you the lack of fab skills I have and take some pics of the bases. So you can see what's going on underneath. Be kind though I'm not master fabricator that's for sure.
    I'll see if I can do it tomorrow.
