Results 1 to 20 of 33
Thread: New US Beat Owner with Gauge Cluster Fuse issue
Hybrid View
    Aug 2016
    Atlanta, GA USA
    Hello All,
    New member here! I've been reading the forum for a while now and just last weekend picked up by own Beat imported into the US. Super excited to say the least, but also concerned at the moment. I have had my gauge fuse blow twice since getting it home on Saturday which causes the car to die (obviously an issue). At first I thought it might have been due to the drive home from where I picked it up which was a 7 hour drive at highway speeds (scary and fun at the same time). Now that it has blown again I am not so sure.
    The first time the fuse blew was on Monday as I was driving back from lunch with the A/C on (this might be important). I was stopped at a light and the engine bogged heavily before finally revving high enough to pull away. Next stop light it was idling at 500 rpm and just died. Quickly diagnosed that it was the gauge fuse and replaced it and drove straight to the auto parts store to get more fuses. With the new fuse it ran perfectly fine, but from the moment I started it up until today I had not used the A/C since it was a partial suspicion that it may have been the culprit. Today the same scenario happened on my way back from lunch again, A/C on, idling at 500 rpm before dying, so I am starting to think the A/C might be causing the issue.
    After replacing the fuse I decided to pay attention to exactly what happens when I turn on the A/C. When I turn on the A/C the engine idle immediately goes from around 1100 rpm down to 900 or less, and it never rebounds like it should to compensate for the added stress on the motor. When I turn it off the idle jumps up to about 1200 or 1300 before settling back down to 1100 or so. I checked the fuse and it seemed a little warm but since I had only tried it for a minute it wasn't definitive at all. Obviously something is pushing a bit too much current through the gauge fuse, but I am unsure where to start looking. Any tips or thoughts from more experience owners!?
    I will be forever grateful for any thoughts, and I am looking forward to being a part of the community! And as a thank you for your help and to cover the internet tax here is a picture of my car and a picture of an adorable otter.
Name:	February-01-2012-23-16-43-otterball (350x350).jpg
    '81 Honda CM200T
    '89 CA6 Accord Coupe
    '91 Beat PP1
    https://www.facebook.com/groups/BeatPP1USOC/
    Sep 2007
    First, quit going to lunch.
    Second, obtain a copy of the wiring diagram (unable to upload). There are 2 leads that travel to the ECU. The compressor clutch relay pink wire tells the ECU to bump the RPM and the Blue / Red from the ECU to the condenser fan relay allow the sys to operate. The AC relays are located on the RH wheelwell. See the blue jumper I had to add when I swapped motors because the Hayabusa ECU does not have A/C circuitry to complete the loop.
    Looking at the schematic, I do not see that the gauges (10a fuse) circuit ever merges with the A/C sys. You mentioned fouling at idle under load. The gauge circuit does feed the fuel pump.
    Unsolicited advice: As most modern elec sys operate on mili-amps, I add 'dielectric' grease to all accessible elec connectors, relays, etc. to form an oxygen barrier preventing oxidation or rust.
    By the way, you are the second Beat owner in Georgia. The first owner sold his in 2009 to the Bruce Weiner Microcar Museum in Madison.
    Attached Files Attached Files
    Aug 2015
    Tohoku, Japan
    Are those Rivazza wheels? Made by Enkei? I've got the exact same ones!
    Aug 2016
    Atlanta, GA USA
    Quote Originally Posted by 4Aaron GE View Post
    Yes they are sir! They are one of the reasons I purchased this Beat, it already had wheels I loved :-)
    Quote Originally Posted by marcair View Post
    Thank you for that great information! I found the wiring diagram in Japanese, still looking for the English translation. I will be going over all the wiring this weekend and fingers crossed I will track down something that is going wrong. As you say, if the A/C does not merge with that circuit but the fuel pump does, maybe the fuel pump is failing?
    As an addition, my coworkers told me that my right brake light seemed dim, but only right before I had the engine and fuse issues, so I am also going to track that circuit and see if there is a short or possibly water in the light (it does have condensation under the plastic).
    The unsolicited advice sounds like some good unsolicited advice, and I will definitely look into protecting all the connections like you say.
    And I will be avoiding taking the Beat to lunch until I figure this out as well ;-)
    Also, that is awesome to hear that there was a Beat in Georgia before mine, I researched the Microcar Museum and sadly it closed and all the cars were auctioned off back in 2013. Sad day for tiny vehicles. My fingers are crossed that I will see another one locally as I am not exactly excited to make another 7 hour trip to another state to meet up with others (at least until everything is sorted). Will update this thread as I know more! Thanks!
    '81 Honda CM200T
    '91 Beat PP1
    Aug 2015
    Tohoku, Japan
    Before you start tearing your hair out, check that your IACV is functioning normally. It should open up when the A/C kicks in. I know that it sometimes sticks in older Hondas.
    Quote Originally Posted by WatchmanPP1 View Post
    PM me, PDF in English available
    Sep 2007
    Re the wiring diagrams, I got mine from someone on the site. Just a pdf but 350k too large. Try multiple drives with out ac to confirm proper engine operation. Pm. Me w tel#
    Aug 2016
    Atlanta, GA USA
    First off, big thanks to old'uns for a translated wiring diagram and some other bits of info, gonna come in handy this weekend.
    My plans are to check out a variety of circuits for possible shorts or overload issues. Then see if any components are failing, specifically A/C and the idle air control valve per marcair's suggestion, and then the possibly faulty brake light. After that I'll just keep driving it around with no A/C to make sure the rest of the systems are operating correctly and no more fuses blow.
    Besides all that, I'm going to go over the rest of the car to find any upgrades or aftermarket parts (pretty sure the brakes are upgraded Fit/Jazz rotors and calipers) to have a better picture of where I'm starting at. Thanks for all the suggestions, I'll update when I learn more.
    '81 Honda CM200T
    '91 Beat PP1
    Aug 2015
    Tohoku, Japan
    I've got a set of RS-R springs if you need them. I gotta dig it out, but I've got an HKS exhaust as well. Would have to find a suitable box to ship that in though.
    Aug 2016
    Atlanta, GA USA
    Sending you a PM-
    Now for the update.
    Okay, so a bit of new information comes to light. I found the brake light was indeed full of water and the socket corroded so I drained the water, heated up the light to remove any drops, and proceeded to seal the entire light with silicone sealant. Sanded and cleaned the socket and bulb and reassembled. Everything seemed to work well. I didn't find any circuit issues elsewhere but I have not tested components for failure.
    I then did some other items that had been on my list, shorten and relocate a ground/earth wire that had been added to the battery terminal, as well as rewire and relocate a battery "enhancer" capacitor unit that was also added. (Might end up removing this in case it is causing unusual surges to the system) I checked some service items to get a list going of what to order. By this time it was getting late and I put everything back together and went for a drive.
    Left the A/C off, fan off, radio off during the drive to make sure that had no effect. It was at night so headlights were on. Did a little spirited driving for about 5 minutes, total drive time was 15 minutes before the idle bogged to 600, I had no throttle response after pulling up to a stop and it died shortly after turning the corner. Pulled the gauge fuse and it had NOT blown. Reinstalled the same fuse, car started just fine and I drove home.
    Today I pulled the main relay and ECU out to check some components because now I am wondering if it is electronic instead of component failure (still planning on removing the IACV/EACV to clean it as well). The main relay seemed fine, no cold solder joints but it's possible the actual relays are bad and it needs replacing. I'm looking for a replacement, probably going to go with something domestic like the RZ-0139 out of early 90's Preludes as they are all the same thing. But now we come to the possible interesting bits. The ECU seems to have a leaking capacitor (I think) where others have had the issue - see pics below.
    Also, there is a very small switch added to a resistor that makes me very curious. I haven't been able to find a limiter cut module added anywhere, even though I am able to redline in 5th gear. Is it possible that this switch is a type of work around for that? My computer system knowledge is incredibly lacking when it comes to that. Or is this something else that could also be causing an intermittent issue that I am experiencing lately.
    I have replaced everything into the car and am going out for another drive to see what happens. Until then have a ponder over the images and I'll return with the second drive results.
    Also, I adjusted the air in my tires last night before the drive (they were all sitting at 32 psi and I dropped them to 28 as per the recommendation on the door jamb). During the drive I experienced a shimmy when over 50 km that I have not had before. I always had a very smooth ride, no shimmy or rough wheel feedback, no issues with road vibration besides a small vibration under aggressive braking I think due to the slotted rotors. Curious as to what may be causing this.
    Thanks - be back soon
    '81 Honda CM200T
    '91 Beat PP1
    Your ecu has been socketed and chipped in Japan so the speed limiter has been removed, as for what map is on the chip it is hard to say may just be standard fuel/ignition with speed limiter removed or it could have slight adjustments to go with the mods on the car if there is any. That little switch is to go between the standard oem setup or to the delimited chip setup.
    As for the capacitors I would replace they as a matter of course that one you've pictured looks a bit of a mess if the eml light isn't on then you still have a good chance of replacing it and not having a damaged pcb, but whoever replaces it I'd get them to check the pcb in that area and have them use some sort of pcb cleaner to make sure any residue from the capacitors are gone.
    If you got the cash I would look on the auctions and get an ecu relocation extension harness it will allow you to relocate the ecu to under the passenger seat so it takes it away from the heat of the firewall, as for your question on the brakes side if they are around 240/242mm vented discs then yes you have a gd1 fit/jazz upgrade.
    Sep 2007
    Re. The Ecu location: check out second skin thermal barrier in Arizona. I bought a variety of materials for heat and sound. When I did the engine swap I lined the engine compartment with thermal and lined the floor and door interiors with sound mat.
    If your ac relays are not on the rh fender, has there been a mod? Maybe suspect.
    My a/c relays are not on the rh fender either. I think they are the two relays next to the fuse panel under the cowl on the rh side. (1994 Model Z)
    Steve
    Sep 2007
    Steve, see my earlier attached pic of the fan and condenser relays. Are we saying the same with different terms or are there 2 different configurations
    Different configurations. I am also aware the parts manual shows them where you have them. They are definitely not there on mine, nor any holes suggesting they were moved. (My car is about as original as they come.)
    Aug 2016
    Atlanta, GA USA
    Great tip on the heat shielding, looks like some quality stuff! I chose to work on other things this past weekend as the car has been driving just fine with no fuses blowing. So one more week and I will start using the A/C again to see if that has any effect.
    Good to know that the relays are probably under the dash, I'll check the wiring diagram to make sure next time I look under there. Just as long as they are somewhere (and there has been no relocation and mucking around with them) I can at least check the system. But I guess we'll see when I get there. Thanks everyone for the info, it's really helping me understand the car a lot better.
    As a side note, I fabricated a custom strut tower brace this past weekend as an experiment in frugality, check out the build process here - http://www.u-ukhbc.co.uk/vbb/showthr...-Tower-Bracing
    '81 Honda CM200T
    '91 Beat PP1
    May 2016
    I have a Beat in Florida. I have brand new RSMach ECU capacitors in my garage if you still need some. I had the thermal layer on my ECU but it still got hot so I got a relocation harness to move it under the seat to prevent that issue.
  18. #18
    Sep 2016
    Quote Originally Posted by CZski View Post
    Hello everyone! So i just purchased a 91 Beat here in California and when the car arrived everything was working fine except the A/C. This past weekend I added the R-134 fitting and filled the A/C system up with new freon and everything was working fine until I turned the car off and tried to start it again. After checking a few things I figured it out was the 10A fuse. Since I have read the advise of many people of this forum my question is, If I just change out the ECU with a new once which I found available in Japan at a Honda dealer, Will this fix my problem?.
    Thanks everyone!
