Omex, Emerald come to mind I know a few people on Minkara have used Haltech to good effect. Combustion shape in the head is slightly different, valve springs aren't as strong, cam is milder, ports aren't as big. e07z is obd2 aswell would make an awesome swap into the Beat though would make driving it daily less of a chore if it was over here but I'd imagine in Japan the e07a is ok. Supposedly not that hard to wire in the e07z ecu but issue with that is they are mostly AT, be interesting to follow if you go ahead with the swap.
For you it would be a near straight swap in terms of getting it in just wiring which most diagrams are available on minkara
