Lambda Sensor needed
Hi
Can anyone give advice as to what Lambda Senor will work ?
I have code 1
The Honda part number doesn't directly cross reference anything else,
So.... what can I use ?
Thanks
hi I recently tried a haas lambda sensor for a civic it is cheap enough (ebay) and its plug and play
also worth investing in a thread chaser and lambda socket as the old one is probably well stuck in there
makes a vast difference to how the car drives as well
or if you speak to hughesy see how he is getting on with his decat pipe
Can I get a link or part number for that haas sensor? I'm pretty keen on getting a new one to keep things fresh, and it might be cheaper than the local honda dealer...
