Rebuilt Honda Beat engine breaking
Having a clear out so have the following for sale
Rebuilt e07a Honda Beat engine from my old car, cambelt snapped so the following got replaced
All inlet and exhaust valves
Thermal inlet gasket
Cam seal
All valve stem oil seals
Timing belt
Water pump
Both Tensioners
Only ran it for 15/20 minutes tops but never used again as the car had a major electrical fault so I broke the car, engine has no starter motor, althernator, aircon pump, injectors or fuel rail. It's pretty much bare apart from the throttle bodies and airbox. Top half of the exhaust manifold is still on which has new gaskets, looking for £450 ono
Located Oswestry, Shropshire. Willing to break the engine for parts
Prices are negotiable, but please bear in mind it's pick up only due to kit being fragile and engine being heavy.
Could pallet the engine up for delivery but you would need to arrange that.
Bump everything for sale still open to sensible offers
Right I am happy to break the engine for parts so the following will be for sale
Rebuilt head with all inlet and exhaust valves replaced, Cam seal, all valve stem oil seals, very mild port matching £220 posted to anywhere in the UK
Thermal inlet gasket £25 posted
Near enough new timing belt kit never had any road miles put on it and was only ever ran on the engine for 20 min max consists of timing belt, water pump and
both Tensioners £120 posted anywhere in the UK
Near enough new Headgasket as above £25 posted anywhere in the UK
Flywheel with good clutch £50
Bottom end £80 collection only due to weight
All prices are pretty negotiable as the parts need to go
bump open to sensible offers
Engine sold pending pick up
