Right I am happy to break the engine for parts so the following will be for sale
Rebuilt head with all inlet and exhaust valves replaced, Cam seal, all valve stem oil seals, very mild port matching £220 posted to anywhere in the UK
Thermal inlet gasket £25 posted
Near enough new timing belt kit never had any road miles put on it and was only ever ran on the engine for 20 min max consists of timing belt, water pump and
both Tensioners £120 posted anywhere in the UK
Near enough new Headgasket as above £25 posted anywhere in the UK
Flywheel with good clutch £50
Bottom end £80 collection only due to weight
All prices are pretty negotiable as the parts need to go
bump open to sensible offers
Engine sold pending pick up
