Originally Posted by
stu g
Ring gap size is:
top = 0.15 to 0.3mm. The up and down tolerance of the top ring in the piston groove is 0.035 to 0.060mm, with a service tolerance of 0.13mm
second = 0.3 to 0.45mm
oil = 0.2 to 0.5mm
Service limit on each is 0.6mm
Head bolt tightening torque is 6.2 - 6.8kg-m. Oil the threads first.
Cylinder head sequence, if you have the camshaft pulley on your right, and they are numbered 1 to 8 from top left to right and then bottom left to right, is 3 6 2 4 1 8 4 5
Note that when you take it off it is 8 1 5 4 6 3 7 2
Conrod cap torque is 3.2kg-m
Hope this helps,
Stu
