Results 1 to 7 of 7
Thread: power trunk release
    Sep 2007
    power trunk release
    Anybody installed a power trunk release? Seems a other Honda model assy may be adapted. Thoughts.
    Hayabusa engine transplant, power trunk release... Is there anything you won't try?
    Sep 2007
    Last summer increased motor from 1300cc to 1550cc. Adding paddles this spring
    Oct 2015
    Amherst, MA
    Can't be too difficult, springs, a little wiring + the sending unit off of a different car. Problem is often those go through the key fob yea? That might require some central security system depending where you get the donor parts from. If you're engine swapped, this'll be a walk in the park.
    Sep 2010
    Wellington, New Zealand
    Not a huge amount of space to play with but it can be done. Here is my effort.
    https://www.youtube.com/watch?v=PJJX__4iQLk
    Sep 2007
    I'm shopping for a small solenoid activated from inside the car. And include a spring.
    Sep 2007
ID:	2690Click image for larger version.
ID:	2688Click image for larger version.
    Installed a direct electronics solenoid assy, fab'd a pop-up spring assy. will install switch above fuel door release in door jam. Total is less than $30
