Thread: O2 sensor fault.... even with new sensor
    Sep 2016
    Lancashire
    Any one any ideas on this
    Engine check light comes on , generally provocted by wide throttle on lower revs
    Car seems to run fine,
    Did a decat , problem same
    Has new exhaust made and fitted a new Honda 02 sensor
    Problem still the same
    Capacitors in ECU also replaced
    So where do I look next ?
    Jul 2005
    Camberley
    OK, I think that several issues might cause the engine check light to come on.
    First things first, what makes you think it is the O2 sensor?
    Secondly, does it seem to have any noticeable impact upon performance?
    Feb 2014
    there's a seperate catalyst light, does that come on?
    which sensor did you use?
    He had a brand new oem part from Honda
    Sep 2016
    Lancashire
    Catalyst light removed ......
