Thread: Ecu
    Ecu
    F**********************************k!!!
    Swapped out the 6 capacitors after reading the threads on this board to try and cure a low rev misfire and now my car will not start at all!!! One of them had been leaking.
    Feb 2014
    there's an ECU on ebay, think the seller is a little optimistic with the price however
    I don't know if Rich (hughesy) has one spare or not? are the tracks on the ecu around the caps ok?
    Jul 2005
    Camberley
    If first you don't succeed, try try again. I expect you just have an iffy bit of soldering, or possibly duff capacitors, or the polarity wrong. Try resoldering it, and then checking the connection with a multimeter. Also, are you sure you've gotten the capacitors the right way around? They are polarized.
    Yes I saw the ebay ECU. I'd rather try Honda for a new one at 500 than risk my money on that one.
    I have taken a day or two off from the ECU to relax a little. Yes I know they have polarity, and I thought I had them all the right way round. But sometimes in a disappointed state mistakes can be made so I will check again. Then check the soldering and test the caps.
    Tracks seem ok but again, I shall check.
    Cheers for your replies guys
    Jul 2005
    Camberley
    Re the polarity, you can tell if it is the right way because of the wider stripe down the capacitor. You can use a reference picture such as this http://blogs.yahoo.co.jp/nowi64/32331325.html to see if yours are correct.
    Cheers for the info and support people. I am going in for another attempt. Will keep you all posted.
