Yes I saw the ebay ECU. I'd rather try Honda for a new one at £500 than risk my money on that one.
I have taken a day or two off from the ECU to relax a little. Yes I know they have polarity, and I thought I had them all the right way round. But sometimes in a disappointed state mistakes can be made so I will check again. Then check the soldering and test the caps.
Tracks seem ok but again, I shall check.
Cheers for your replies guys
Re the polarity, you can tell if it is the right way because of the wider stripe down the capacitor. You can use a reference picture such as this http://blogs.yahoo.co.jp/nowi64/32331325.html to see if yours are correct.
Cheers for the info and support people. I am going in for another attempt. Will keep you all posted.
