Brake discs and callipers
I'm back! been a way for a while. life can certainly get in the way of getting my Beat back on the road!
Brake Discs and Callipers?
any recommendations for upgrade or replacement? I've seen a few things on here for discs and pads but not much on callipers. so anyone with any info or links could you please pass it my way thank you.
Honda Jazz GD1 240mm vented calipers discs and pads work, Pav AUS member has done the conversion said all you needed to do was remove the backing plate from the front and that was about it. If I had one then this would be one of the first things I do to it, would probably do braided lines and new fluid at the same time.
cheers Gavin
I'll look into that I think i found the thread. so I will investigate and make some enquiries.
