Results 1 to 17 of 17
Thread: Stereo off on button?? not working??
    Apr 2017
    Ok beat people, whats the score with these Gathers stereos. Got the car running, had the stereo playing and changing cd's from the boot.
    on off button a bit dodgy, now doests work. tried a cocktail stick with button off-worked once. Are they easy to get out and after that do they come apart ok?
    as always thanks in advance
    Nigel
    (france)
    common issue i'm afraid.
    just looked in my box of leftovers from the unit i butchered to fit my Fusion radio and you can't even use a 5-6 button upside down as they are different sizes as the unit tapers.
    assuming the small plastic stalk at back of button has broken?
    behind the Grey cover there are clear plastic pieces to transmit light to buttons, then a gel covering over the buttons but with holes so the plastic stalks go directly onto the micro switches.
    i've got a pic somewhere of the PCB, i'll try and upload later for future reference
    re: the other post about 3D printing, it looks as though the buttons are clear plastic then coated Grey and the letters/numbers etched back out
    /\ what mine looks like now
    Apr 2017
    just found new button sets on a japanese auction site
    http://yahoo.aleado.com/lot?auctionID=231456594
    Apr 2017
    Apr 2017
    my on off button still has its stalk, one of the rocker clips is broken. But i can feel it clicking the button underneath, i guess that must be where the problem lies. you have a very different system now?
    just a little....
    stripped out all the wiring, dash speakers and subwoofer and replaced doors with components, 2 small & tweeter in each dash pod replaced, Amp behind the passenger seat and HU with a Fusion Marine unit.
    all the info on mine and a few others is on here somewhere, mainly under the sounds sub-forum i think?
    Aug 2015
    Tohoku, Japan
    Quote Originally Posted by triton23 View Post
    Interestingly, both of those are listed as "new", rather than "used". I think I'm going to swing by the dealership after work and do a bit of research.
    Apr 2017
    Let us know how you get on
    Apr 2017
    Well the unthinkable happened, got the unit out, as carefully taking off the front face to reveal the buttons, I dropped the screen and it pulled the ribbon from the circuit board. I'm so cross with myself. Has anyone successfully re soldered the ribbon on. Are there any screen modules out there to be had?
    Sep 2016
    Lancashire
    Quote Originally Posted by old'uns View Post
    That's a neat remedy.....
    Think I will have to follow suit....
    Are all marine radios narrow or is it just the fusion brand ??
    I have an old original radio front I can use to fibreglass up a surround.....
    Aug 2015
    Tohoku, Japan
    Finally got a chance to get out to the dealership. Turns out that they don't sell them. Not sure where this guy is getting his, then.
    Sep 2016
    How did you go about taking the front face plate off? My Volume up button doesn't work, I'd like to take swing at fixing this if possible. Any help will be appreciated!
ID:	2719Click image for larger version.
ID:	2720Click image for larger version.
ID:	2721Click image for larger version.
    cage held in by the 2 screws/bolts just level with the plastic trim
    usually not a lot of slack on cables as you pull cage out
    2 screws top and bottom hold the fascia on
    Sep 2016
    Thanks for the quick response and the excellent information! What do you think my chances are of getting the volume button to work? I've poked a few assorted things trying to get it to respond and nothing has worked. Any recommendations as to what I should try to poke it with?
    Mark
    cocktail stick, small nail, anything small, it's only micro switches that are activated
    If the bar the switch pivots on is broken glue something across where it was. From memory (this was a long time ago) I used a bit of an ice lolly stick. Missing prongs can be improvised and glued in place on the back of the switch. If the pivot clips on the back of the switch are broken use a small dab of silicone sealer or other flexible adhesive.
