Thread: Centre speaker & Amp upgrade
    Sep 2016
    Lancashire
    I have recently got my hands on a center speaker assembly, but without its loom...
    Does anyone have a pinout of the plug that fits this ??
    or any advice on what fits ???
    So far I have fitted a separate DAB unit that feeds the original stereo via the FM cable... the DAB unit also has AUX in and iPod control..
    To boost the volume I have spliced in some simple ebay amplifier circuit boards... amplifies the noise as well as signal but in the Beat not an issue, means I can listen to music above the engine on the motorway (if I want to)
    like these (http://www.ebay.co.uk/itm/DC-12V-26V...algo=undefined)
    good luck on finding a 4" Bass speaker....assuming the paper cone is worse for wear
    few pics of wiring that was in mine before i stripped it out
    the wiring for the 120w system is complicated, look through the audio threads.
    the dash speakers are split but not L /R....i 'think' that 1 speaker & tweeter from one side and 1 speaker from the other are linked and vice versa for Spatial sounds?
    there also appears to be a lot of wires going to the Amp but not too sure what goes on with that.
    the only wiring diagram i have is this one of the rear of unit...bottom half is 120w system
Name:	clarion w diag.jpg
    Aug 2015
    Tohoku, Japan
    Quote Originally Posted by old'uns View Post
    If you can fit a 4.5" speaker in there, Tang Band makes a subwoofer that's supposed to be good down to 35hz.
    https://www.parts-express.com/tang-b...4-ohm--264-952
    And if you don't need that bottom octave.
    https://www.parts-express.com/hivi-b...frame--297-429
    These Daytons looks like they would do the trick as well
    https://www.parts-express.com/dayton...oofer--295-328
    https://www.parts-express.com/dayton...4-ohm--290-212
    Or take your pick
    https://www.parts-express.com/cat/mi...7C0&PortalID=1
    The hard part is not getting shafted by the postage.
