Thread: Tonneu front stud
    Apr 2017
    Question Tonneu front stud
    Hi
    I can't fit my tonneau front stud to the car (the same stud you have to undo when folding the roof).
    I want to either change the stud or buy a new tonneau ...
    But If I have a look here https://page.auctions.yahoo.co.jp/jp/auction/l404353070 -> https://auctions.c.yimg.jp/images.au...vueop10279.jpg
    It looks like the same stud as on my tonneau.
    Am I missing something?
    If I remember correctly from my first Beat (9 years ago so I may be wrong) Honda used 2 different fittings for the front of the roof. The original was a Tenax fixing that was replaced on later models with a simple stud When I tried to order a replacement pair of fixings (I had the same problem as you) Honda supplied me with the later stud type, the original part had been superseeded.
    It sounds like you have a late tonneau and an early roof. The simple solution would be to buy a pair of fixings from Honda (90306-SS1-505) and replace the fixings on the hood.
    As fxdlidon says the original fixing are tenax fittings, if you want to get some they are available from the supplier Namrick
    http://www.namrick.co.uk/acatalog/Ho...ated__165.html
    You would need the machine screw type to fix to the body.
    The later fixings are just normal press stud type fixings which Honda now supply.
