Thread: Fuel pump
Hybrid View
    Manchester UK
    Fuel pump
    Does anyone have a step by step to remove the fuel pump? I'm assuming the fuel tank needs to come out too, so some guidance would be great to know.
    No, tank stays in. Remove parcel tray cover, remove pump cover bolts, disconnect wiring harness and hoses, pull up and out pump/sending unit.Click image for larger version.
    As I've got it apart today...
    You just need to remove the drivers side parcel shelf (7 bolts) - no need to unbolt the seat belt, just extend it and rest the shelf on the roof.
    Make sure you take off the fuel filler cap before taking off any fuel lines, to remove any pressure in the tank, or you'll get fuel spraying everywhere.
    Manchester UK
    I feel a bit silly asking now, I've worked on the engine in the past and it hadn't registered that it was there and so easy. I searched for pics but did'nt see any and I had visions of this was going to be an awkward under the car type of job.
    Thank you for those great pics guys!
