- Forum
- U-UKHBC
- Need a new clutch slave cylinder... discontinued!
Hi Guys,
Bleeding the clutch worked a couple of years ago (Clutch-going-going-gone!), but this time all I got was a pool of clutch fluid on the concrete!
Off goes the Beat to the local garage and they've diagnosed a leaky clutch slave cylinder. From earlier posts, it looks like the part number is 46930-SS1-003, which www.parts-honda.uk shows as discontinued
It looks like I can get one from Japan from either http://yokohamamotors.net/honda-beat...ails.html#1750 (£82 delivered) or https://jp-carparts.com/honda/part_s...=SS1&part3=003 (£63+delivery), but they're both from Japan and the whole of Japan is on holiday until may 7th!
And then there's https://www.diyspareparts.com/parts/...l-46930ss1003/ (£200) here in the UK with 2-3 day delivery, but ouch, the price!
Does anyone have any other sources? Or one lying around I could buy?
Here's hoping, Thanks!
-Jc.
Hello Jc
I'm afraid I haven't got a slave cylinder but I really enjoyed reading your previous post, I was there with you pulling the clutch pedal back up!
Have you considered re-sleeving the old one?
http://www.pastparts.co.uk/index.php...formation_id=8
Good luck!
Andrew
Fixed!
The guys at pastparts said they'd need to see the cylinder to diagnose, so I asked my usual garage and they found a kit of parts which looked about right and cleaned it up themselves in about an hour. No guarantees, as it was quite badly scored inside, but still good after a few weeks. Fingers crossed!
I might just buy a spare from Japan, just in case.
Hope this helps someone in the future
